Print advise with PETG
josescxavier
(@josescxavier)
We received our printer yesterday and start print some objects. We notice a big difference on print quality between two similar prints.
V2:
V1:
V1 is on the left and is the one thats look good and the one on the right is V2 and doesn't look too good.
You can check the STL files here https://drive.google.com/open?id=1aaDnUSEzSm7Y4iton-AhyctmemJOszTK
The filament is prusament PETG.
Opublikowany : 25/09/2019 12:38 pm
RE: Print advise with PETG
the attached  files seem to be Gcode not STL
Opublikowany : 25/09/2019 2:10 pm
josescxavier
(@josescxavier)
Posted by: @joantabb
Fixed: https://drive.google.com/open?id=1FD25II-uNc4WztqWZP1WLRjwc_JG2ATp
This post was modified 7 years temu by josescxavier
Opublikowany : 25/09/2019 2:35 pm
Hi Jose,
I am not sure what to recommend...
seemed to print Ok for me!
zipfile attached
Joan
Attachment removed
Attachment removed
Opublikowany : 25/09/2019 6:34 pm
josescxavier
(@josescxavier)
@joantabb
I tried with PLA (left) and it is perfect:
pla version
I'll try with your gcode, which settings did you choose?
PS: you are printing at 240 but the preset for PETG prusament is 250.. hmm..
Opublikowany : 25/09/2019 6:40 pm
Bunny Science
(@bunny-science)
Try slicing from this 3mf which includes my standard PETG settings. Unzip. Open in PrusaSlicer. Click slice now. Export the gcode.
Attachment removed
Opublikowany : 25/09/2019 7:46 pm
Also - those first gcodes, one is at 0.15 mm layers, the other is 0.2 mm layers; so adhesion and cure are different.
Opublikowany : 26/09/2019 8:30 am
josescxavier
(@josescxavier)
Posted by: @tim-m30
I tried the second design with 0.2mm with the same problem. I'll try the first design and see how it prints.
Opublikowany : 26/09/2019 8:40 am
