Preheating the Nozzle without the Heatbed - possible?
Hi Everyone,
trying out the tricky Flex Filaments, Filaflex / Polyflex.
Is there a Chance to Preheat the Nozzle without heating the bed?
Both don´t require a heated bed, had to reload due to Loops in the Gears and can´t Preheat without also heating the bed, right?
Thanks in Advance,
Al
Re: Preheating the Nozzle without the Heatbed - possible?
in Slic3r, you can set the bed temperature to zero!
or you can choose settings on the LCD, then temperature, bed and set to 0
Thank you Joan,
the Settings in Slic3r have been made.
But can I Preheat the Nozzle on the Printer during a Print (because the Filament ran Havoc) without heating the bed?
On the printer: Settings > Temperature > Nozzle
instead of Preheat.. is that what you're looking for?
If you use OctoPrint you can set Nozzle and Heatbed temperatures separately
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Hi Al.g
on the LCD display, you can access the menu 'Settings' and sub menu 'temperature' and the sub option Nozzle. where you can select the temperature that you want.
this can be used to preheat the nozzle before a print, or to change the temperature of the nozzle during a print!
I hope this helps you,
