Power supply voltage
joaquin.o3
(@joaquin-o3)
Hi, I just finished the i3 MK3 assembly, and before I do anything (self-test of course), I want to be sure that the printer will not blow up or burn! jaja
Here in Chile the voltage and frequency is 220V 50HZ. Should be ok connecting directly?
Thanks!
Postato : 20/02/2019 10:07 pm
Re: Power supply voltage
Should be fine.
About the same as the uk...
Joan
Postato : 20/02/2019 10:42 pm
DaJMasta
(@dajmasta)
The included supply has a wide input range, one usually called a "universal" supply because almost every country's standard power voltage and frequency is compatible. Just gotta get the right wall plug to IEC plug cable to get to the PSU and you should be fine.
Postato : 21/02/2019 4:07 am
