Power Supply has failed
Hi There,
I bought the kit and assembled. All went smoothly and used the printer for a few days with no problems. Except I did notice that the power supply was always quite hot. A clue that it was about to fail. And it did. The label on it says 24V 10Amp. I had another power supply(24V 20A) nearby on older reprap and hooked it up. The printer is working again. But I need a new power supply. Does Prusa have any kind of replacement warranty for this? Order #182141742
Thanks,
Rich
Re: Power Supply has failed
The MK3 power supply is listed in the prusa shop https://shop.prusa3d.com/en/mk3-printer-parts/207-mk3-psu-24v-240w.html
You might have to ask support chat (lower right corner of the shop page) to get access to the MK3 spare parts section. And once you're in chat, you can ask them if they honor it was a warranty case as well.
