poor print qualit
jorgen.r
(@jorgen-r)
poor print qualit
Good morning from Norway 🙂
Today i was hoping someone would help me with my print quality. i got some ugly lines everyvere, post some pictures. the prints is printed with Chris Warkocki's pla and petg profile. i have also printed with my own and others profile with similar result.
I have checked my belt tension which is 262 and 268 on x an y axis. The hotend is also not loose.
link to prints
https://imgur.com/a/swL2vaC
https://imgur.com/a/Kaf6DRL
Hopefully someone have tips for me. 🙂
Have a nice weekend.
Publié : 02/03/2019 9:14 am
RH_Dreambox
(@rh_dreambox)
Re: poor print qualit
Check out these points:
Make sure that X- and Y-end pulley can rotate completely freely.
The toothed belts must not shave against any component.
Loosen the Z-screw covers so they can rotate freely.
Check that the two Trapezoidal nuts run easily on the motor shafts.
Loosen the screws of the Trapezoidal nuts so that they do not "snap" against the motor shaft.
It can also try a different color on the filament. It may be that white PETG behaves differently than a darker color.
Publié : 02/03/2019 10:00 am
