Poor first layer and corner lifting
ScottM
(@scottm-2)
I am making cases for voltage meters and the first layer is the top surface that will be seen by the user. How to I print it so that it is much smoother than this? Also, the corners are lifting a bit. I used slicer 2.5.0 win64 and the filament is PLA from fliaments.ca printed at 215/60 for first layer. I used the Prusa PLA profile as is.
Postato : 21/01/2023 2:54 pm
towlerg
(@towlerg)
Try lowering Z a little, to get a bit more squish onto the bed.
Questo post è stato modificato 3 years fa da towlerg
Postato : 21/01/2023 3:10 pm
I would also test other bottom fill patterns, such as Hilbert Curve...
wbr,
Karl
Postato : 21/01/2023 4:22 pm
ScottM
(@scottm-2)
RE: Poor first layer and corner lifting
Hilbert Curve pattern looks worse. I lower Z a bit to increase the squish. First layer filament width is 3x height, so it should be good. I lowered first layer speed to 15 mm/s but I still get a raised corners, even after cleaning with soap and water and isopropyl alcohol. I also ran a full calibration. I think there are probably small areas of the bed that aren't level. I did see a post once about a program that can micro map the surface for better adjustments, but I don't remember where I saw that.
Postato : 21/01/2023 8:56 pm
That is nowhere near squished enough.  Then again nether  was your first layer in your original pics.  Get it down more.  Should look like this -
Postato : 21/01/2023 10:25 pm
