PINDA probe
holten.c
(@holten-c)
PINDA probe
I've been having issues with first layer consistency since I installed MMU2. I noticed the extruder assembly doesn't hold the PINDA in such a way that the bottom of it is parallel with the bed. I'm not entirely sure what the PINDA uses to make it's measurements so I'm not sure if a slightly tilted PINDA can affect such things.
Can a slightly crooked PINDA affect print quality?
Napsal : 14/10/2018 6:36 pm
toaf
 toaf
(@toaf)
Re: PINDA probe
it could.
Napsal : 15/10/2018 12:31 am
Olef
 Olef
(@olef)
Re: PINDA probe
The PINDA base should be parallel with the bed. If it is not I suggest you need to discover why and rectify it, as the extruder parts it is mounted on should present it to the bed correctly. Perhaps a slight error in assembly, or a damaged part is the cause? If you post up a couple of pics perhaps we can offer ideas?
Napsal : 15/10/2018 7:54 am
