Pei spring steel sheet
DaHc
 DaHc
(@dahc)
I just received my mk3. After looking everything over it seem that my pei sheet has a soda can effect. When you bend it a little it pops. Is this normal?
Opublikowany : 25/09/2018 4:06 pm
Peter L
(@peter-l)
Re: Pei spring steel sheet
Mine doesn't do that, but I would see if it's causing problems before getting too worried. The magnets in the heatbed are pretty strong and might flatten it out.
Opublikowany : 25/09/2018 8:37 pm
DaHc
 DaHc
(@dahc)
That is what I was thinking. I wanted to ask to be sure. I will post back if I see any issue after assembly.
Opublikowany : 25/09/2018 9:03 pm
nathan0876
(@nathan0876)
Mine does that when you bend it to one side but not the other side.
In any event it hasnt cased any issues and ive printed over 10KG's of PETG on it so far.
Opublikowany : 25/09/2018 10:13 pm
