Nozzle catches paper - how to proceed?
During calibration, the nozzle caught the paper (on a pre-assembled printer - I'm a bit sad). I powered off as described and lowered the probe holder - hopefully in a correct way. After that, it says I should calibrate XYZ again.
Can I just turn on the printer again? Shall I remove the paper first? If so, how? It sticks in the nozzle.
Napsal : 08/11/2018 9:39 pm
Re: Nozzle catches paper - how to proceed?
Screw the extruder a bit up (Z-axis), lower the P.I.N.D.A. a bit and try again.
Napsal : 09/11/2018 10:17 am
Topic starter
answered:
I did so when the printer was turned off. I was then able to remove the paper.
Thanks.
Napsal : 11/11/2018 2:52 pm
