Not printing well the tests
Samuel Jiménez
(@samuel-jimenez-2)
I had to change the extruder because it was completely messed up. I've just tried to print again and it looks horrible. What do I need to do to calibrate and make it work well? I did the wizard and one more calibrations from those available. But this is not looking good.
Thank you
Napsal : 21/06/2024 10:38 pm
RE: Not printing well the tests
Nozzle looks way too high. Redo your first level calibration with anything other than the built in tiny square, e.g., https://www.printables.com/model/105404-calibration-strip-for-simple-live-zfirst-layer-cal
When you make changes to the extruder, more likely than not you've changed it's height so you need to get your live Z readjusted.
Napsal : 22/06/2024 12:11 am
samuel.jimenez
(@samuel-jimenez)
Posted by: @fuchsr
Thanks! This problem was solved 🙂 Now I have another one: the printing is not constant and I kinda see it's not smooth. How can I solve that? I attach a picture.
Thank you
Napsal : 25/06/2024 10:20 am
samuel.jimenez
(@samuel-jimenez)
Any help?
Thanks
Napsal : 26/06/2024 7:42 am
Still too high.
Napsal : 26/06/2024 8:01 am
samuel.jimenez
(@samuel-jimenez)
You were right, thanks! I didn't know it could go so low 🙂
Napsal : 03/07/2024 9:45 am
Angel
(@angel)
Hello everybody!
I'm having trouble calibrating my prusa mk3s+. After greasing the axles, tensioning the belt and calibrating the bed and the Z axis, it still causes these gaps in the central impression of the mesh.
Could you help me? thank you so much
Napsal : 30/07/2024 7:51 pm
Tweak your first layer 'Z' offset calibration until the centre square is correct, then follow the procedure on: https://help.prusa3d.com/article/bed-level-correction_2267
Napsal : 31/07/2024 11:08 am
1 lidem se líbí
Angel
(@angel)
After trying this I solved the problem!!!
I just needed a little more patience 😀
Thank you for your help Diem
Napsal : 31/07/2024 7:54 pm
