Normal then under extrusion
Ali Jennings
(@ali-jennings)
Bit of an odd one, and an issue that has just started happening after updating firmware. Essentially the first few seconds of extrusion is fine, then the printer starts under extruding and I cannot get anything to stick to the build platform. I've recalibrated, taken off the nozzle, cleaned wiped and still the same issue.
Anyone have any ideas?
Napsal : 22/03/2020 9:34 pm
RH_Dreambox
(@rh_dreambox)
RE: Normal then under extrusion
Fingerprints on the bed?
Then clean the bed with detergent and warm water, wipe with paper and then do not touch the bed with your fingers.
Napsal : 23/03/2020 1:33 pm
