Noob - Need assistance fine tunig
Wally
(@wally)
I have assembled my MK3, had a few hiccups, but all running OK now.
Printed different things, from Marvin to Dragon, and some thingiverse items, went good.
Just printed the Benchy, and wanted to know if this is a good final print or if there are tweaks I can make.
Also, knowing what the dimensions of Benchy should be, has anyone actually measured their Benchy prints to see how accurate they are? I am finding them to be within 0.05 and 0.2 mm of the correct dimension.
Main concern is the back corners of the print. The bottm stuck to bed very well, can see the lines, but if you feel it the bottom is smooth.
Publié : 03/05/2018 5:05 pm
thrawn86
(@thrawn86)
Re: Noob - Need assistance fine tunig
your first layer might be a little low since you've got some elephant's foot going on. The zits on the back are from retracts/restarts, so you can play with adding little bit of coast setting and/or aligning the seam so that it looks better.
Don't focus on the exact dimensions until you've got other issues sorted out, but ~.1 is about as good as you'll get without driving yourself insane.
Publié : 06/05/2018 6:46 am
