Noisy printer even in steath mode
evs
 evs
(@evs)
My printer works fine. Only it is noisy. It is noise in all the axes especially the Y. The noised part is infinity not the fan.
The noise is generated when a axis change direction.  Is there something I can check or do about is?
Thanks.
EVS
Napsal : 22/12/2020 11:41 am
RE: Noisy printer even in steath mode
Quite often extra noise is caused when the printer resonates with the surface it's standing on.
Four thing to try:
Move the printer to a different worktop.
Stand the printer on a sound absorbing surface eg., rubber mat.
Stand the printer on a HEAVY base eg., concrete paving slab.
Place a heavy weight (10kg+) next to the printer to change the resonant frequency.
If it's still noisy there might be a problem with the printer.
Hth, Cheerio,
Napsal : 22/12/2020 1:29 pm
