Noisy printer even in steath mode
My printer works fine. Only it is noisy. It is noise in all the axes especially the Y. The noised part is infinity not the fan.
The noise is generated when a axis change direction. Is there something I can check or do about is?
Thanks.
EVS
Posted : 22/12/2020 11:41 am
RE: Noisy printer even in steath mode
Quite often extra noise is caused when the printer resonates with the surface it's standing on.
Four thing to try:
Move the printer to a different worktop.
Stand the printer on a sound absorbing surface eg., rubber mat.
Stand the printer on a HEAVY base eg., concrete paving slab.
Place a heavy weight (10kg+) next to the printer to change the resonant frequency.
If it's still noisy there might be a problem with the printer.
Hth, Cheerio,
Posted : 22/12/2020 1:29 pm
