No power after initial heat up..
TheCrow13
(@thecrow13)
After going through all calibrations fine, the printer went into heat up then shutdown. I have the new black power supply that is supposed to auto switch to 110/220. I tested the fuse with a multimeter and it is fine. LED on power supply is not lit. I also disconnected all wire from the power supply and still nothing. Thanks for the help...
Opublikowany : 26/10/2021 10:05 pm
For a new printer with power supply issues you are safest to go directly to Prusa support.
For support: Log into your Eshop account, navigate to support and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Opublikowany : 27/10/2021 12:08 am
TheCrow13 polubić
Dan Rogers
(@dan-rogers)
Push the plug into the power unit REALLY hard
Sometimes it is just the plug is not seated into the socket
Opublikowany : 27/10/2021 9:41 am
TheCrow13
(@thecrow13)
Wish it was just the plug...
I tried that, tested the cord and also used same to power a monitor and all  showed fine.
I contacted Prusa and they are sending a new power supply, but they are not sure of the cause or why fuse didn't fail first.
Opublikowany : 27/10/2021 6:08 pm
