Next level first layer dial-in method
doctorg
(@doctorg)
Everyone loves printing the 75x75 square as it does a great job at dialing in the Z-height to an almost perfect setting. This is a great step in the process, but I have also found that printing narrower objects can help to dial in that setting even more. I noticed I get a great first layer using the 75x75 square method, but when printing something narrower, things tended to roughen up a bit. So, I use the attached STL (part of a bookmark design) to fine tune the numbers a bit further.
For example, a Z height of 1.25 on my setup yields a great square, but leaves the edges of the narrow test a bit rough. Further adjusting down to 1.11 yields great results on both.
This works well for me, I hope it works well for some of you. This is my first Prusa build, but I found with my previous printer, printing smaller narrower objects helped to tighten things up.
Enjoy!
Posted : 23/04/2022 11:34 pm
doctorg
(@doctorg)
RE: Next level first layer dial-in method
Sorry, I meant to say -1.125 to -1.110.
Posted : 24/04/2022 12:24 am
RandyM9
(@randym9)
Thanks for your input. I didn’t see a file attachment?
Esteemed forum user @fuchsr has created a modification to the well known ‘life adjust z - my way’ process that I assume you’re referencing.
His redesign is here:
https://www.printables.com/model/105404-live-zfirst-layer-calibration-strip
His version provides a longer rectangular reference area with tick marks to indicate when the make your live z adjustments. It’s a very nice tool and a great alternate to the original.
Thanks fuchsr!
Posted : 24/04/2022 5:47 am
doctorg
(@doctorg)
Thanks, @randym9, it seems I needed to attach it as as a zip file.
Posted : 24/04/2022 5:51 pm
doctorg
(@doctorg)
Posted by: @randym9
Thanks fuchsr!
Lots of great options available. I think even narrower can be a better test.
Posted : 24/04/2022 6:48 pm
RandyM9
(@randym9)
Posted by: @doctorg
Posted by: @randym9
Thanks fuchsr!
@doctorg - Agreed! I will download your file and give it a go. Thanks for sharing.
This post was modified 4 years ago by RandyM9
Posted : 26/04/2022 5:13 am
