New Printer. Won't extrude
gigem2
(@gigem2)
Newly assembled MK3S.
Loaded filament during the setup wizard, and the filament extrudes correctly. The machine moves on to the z-height adjustment and doesn't extrude. The calibration times out. I start the wizard over again. When it asks if filament is loaded, I select no and it extrudes correctly. I raised the drive gear pressure to see if that was the issue. When the z-height adjustment steps starts again, nothing extrudes... 😐
TL;DR
The extruder extrudes during the load sequence but not when calibrating.
What is happening?
Postato : 19/03/2020 6:00 pm
gigem2
(@gigem2)
RE: New Printer. Won't extrude
So, it's fixed.  I ejected the filament, re-inserted it, manually fed the extruder from the menu, and it worked.
Magic.
Postato : 19/03/2020 7:41 pm
rmm200
(@rmm200)
Keep your filament sensor turned off until you have time to check it out.
Not needed for actually printing.
Postato : 19/03/2020 11:20 pm
1 persone hanno apprezzato
