New MK3 Kit build with inop Z axis motor
gregory.l2
(@gregory-l2)
I just finished building a brand new MK3 kit and one Z axis motor will not run. If you have the machine on and try to turn the wormscrews the one that runs is resistive to turning and the one that doesn't run turns freely. With the machine off both screws turn freely. Switching the leads on the motherboard moves the problem to the other side. Anyone have this issue before? I emailed Prusa and I am awaiting a reply.
Posted : 01/07/2018 9:32 pm
john.d42
(@john-d42)
Re: New MK3 Kit build with inop Z axis motor
same. bump
Posted : 12/08/2018 12:17 pm
This sounds like a solder or pcb issue
Both Motors use the same Driver
So it's one socket that is faulty
Regards Joan
Posted : 12/08/2018 2:46 pm
Have a chat with Support
Regards Joan
Posted : 12/08/2018 6:08 pm
