New Member Here. Issue Wiring Power Panic 0.4 On Silver PSU
victorious416
(@victorious416)
Hi guys, I'm almost done with my MK3S setup.  Just have a few wiring questions before i check if everything is connected properly and do a calibration test.
First question is, on the silver PSU there was a 0.4 power panic daughterboard with 3 soldered wires.  B&W wire (wired it to the Einsy Rambo no issues).  And the other soldered wire was a red one soldered to the 24v connection on the power panic, but I'm not sure what it's suppose to connect to, since the length is much shorter  than then B&W wires.  Here's a pic...
Second and 3rd question are sort of similar, so I'll ask it together.  For the LCD connectors (2) and the fan connectors (2), does it matter which slot they go into.  Will it fry the board or just give an error and let me know its connected wrong.  I accidentally started wiring everything up then when I got to these steps saw that my 2 fan connectors and 2 LCD connectors have similar connectors now I'm not sure which is which.  Is this crucial?  Or will both supply power correctly regardless?
Thanks
Best Answer by Dave Avery:
it connects to the 24V output of the supply ( screw terminal)
Napsal : 10/08/2019 8:04 pm
RE: New Member Here. Issue Wiring Power Panic 0.4 On Silver PSU
Very bad idea to route the red wire over the top of the frame here:
Napsal : 10/08/2019 9:20 pm
As for FAN and LCD wires,  have you read the assembly guide?  If not, you are in for some rather fun times.
Napsal : 10/08/2019 9:21 pm
victorious416
(@victorious416)
Posted by: Tim
Hi. It's not.  I'm asking where it goes......  It's not configured for anything yet....
Napsal : 10/08/2019 9:28 pm
victorious416
(@victorious416)
Posted by: Tim
Definately.  Just wanted to hear how critical it was for the connectors in this case...
This post was modified před 7 years by victorious416
Napsal : 10/08/2019 9:29 pm
Dave Avery
(@dave-avery)
Napsal : 10/08/2019 10:11 pm
1 lidem se líbí
victorious416
(@victorious416)
Posted by: david.a66
Awesome!  Thank you David 😉
Napsal : 10/08/2019 10:18 pm
spellcastersphynx@btinternet.com
(@spellcastersphynxbtinternet-com)
hi, can i jump in on this topic, the short red wire go to 24v output on the silver psu, the plus i take it? alsa in the past i removed the panic switch,got three heavy wires, black blue and green with a tracer, the green go to earth on the psu, blue i think is live and black i think is negative, can anyone confirm, cheers gax
Napsal : 18/03/2026 9:06 pm
another thought, i saw a diagram but dont know if it relate, a jump lead from the -v to earth?? surley not?
Napsal : 18/03/2026 9:09 pm
