New i3 MK3 printer with clogged nozzle
Omar
 Omar
(@omar)
I bought a new assembled i3 MK3. when I started loading the new filament nothing came out of the nozzle. I cleaned it twice with the needle and smoke came out. It looks like testing material is clogged in the hotend. I tried all steps in this forum with no luck.
Publié : 18/12/2020 3:59 pm
RE: New i3 MK3 printer with clogged nozzle
Try doing some cold pulls. Be careful with those needles as they can break off easily inside the nozzle. I quit using them once I discovered cold pulls. If you have no luck, log into the online store and contact support via chat. They are very helpful and will work through the problem with you.
Publié : 18/12/2020 4:14 pm
Posted by: @omar
Try pushing the filament through at a slightly higher temperature, e.g. 260-280 degrees C.. If this does not work, there is a blockage either in the idler shaft or in the PTFE. The best way to remove this is to disassemble the hotend.
Publié : 18/12/2020 6:57 pm
