New build - IR sensor not detecting filament
HeneryH
(@heneryh)
After initial build, my IR sensor was not detecting filament.  Following the inspection instructions, this is what I see...
The link below should be a video, I was getting errors linking a YouTube
Prusa IR
I'll keep digging but any ideas would be very much appreciated.
Thanks
Best Answer by HeneryH:
Fixed.  I thought that insert that was added to the einsey board prevented the inaccurate insertion of the connector but it doesn't  I had it plugged into the top row of pins instead of the bottom row.
Was that orange insert supposed to prevent that mistake?
This topic was modified 6 years temu by HeneryH
Opublikowany : 09/06/2020 6:04 pm
HeneryH
(@heneryh)
RE: New build - IR sensor not detecting filament
Argh, darn it.  Codec problems.  Trying to fix it.
Opublikowany : 09/06/2020 6:35 pm
HeneryH
(@heneryh)
Can't edit older posts.
Also can't seem to embed but this link should be the video
Prusa IR detect
Opublikowany : 09/06/2020 6:42 pm
HeneryH
(@heneryh)
Opublikowany : 09/06/2020 7:01 pm
@heneryh
Use the orange frame if MMU2S is connected:
MK3S/MMU2S:
MK3:
Opublikowany : 09/06/2020 9:04 pm
