[Risolto] New build initialisation won't get past setting language
alidaf
(@alidaf)
My first build completed. Checked all cables again but after turning on the display shows a language select. After selecting, it says something about sorting files before clicking and then going back to the language select menu. Soooooo, what's up with that?
Best Answer by Neophyl:
You aren’t pressing the X button are you ?  That’s printer reset. You push down on the rotary dial to select enter.
Postato : 12/11/2021 5:14 pm
RE: New build initialisation won't get past setting language
Postato : 12/11/2021 5:18 pm
1 persone hanno apprezzato
alidaf
(@alidaf)
Aha, brilliant. I new I was going full tard. The dial doesn't have much give so it didn't feel like a button.
Postato : 12/11/2021 5:44 pm
alidaf
(@alidaf)
It is something of a wonder to see something that has been quite a challenge in parts to put together, working. My first printer was the Mini+,which doesn't have an extra button hence the assumption. I'm not sure if I'll buy another kit though but I'm glad I tried it at east once.
Postato : 12/11/2021 5:52 pm
alidaf
(@alidaf)
I know I spelled knew wrong. Just spotted it, can't edit it. Eejut.
Postato : 12/11/2021 5:53 pm
