New assemble (I3/Mk3) - Wizard reboot cycle - no diagnositcs...
Newly assembled printer LCD screen only shows:
1) Turn on
2) After startup asks for config wizard
3) Select either yes or now causes reboot
4) Cycle - No diagnostics.
The Z axis seems to be controlled (can't move it - cost steppers are engaged), X & Y can be turned (no control/current to them.)
Thanks
Posted : 03/07/2018 5:48 pm
Re: New assemble (I3/Mk3) - Wizard reboot cycle - no diagnositcs...
Are you pressing the knob in to select or are you pressing the reset button under the knob?
If you try and take a cat apart to see how it works, the first thing you have on your hands is a nonworking cat.
Posted : 03/07/2018 10:20 pm
Topic starter
answered:
Umm, Thanks, I had just figured out that the 'x' located right next to the rotary not is the reset button... (Opps)
Posted : 03/07/2018 10:23 pm
