My first cubic print
JKL
 JKL
(@jkl)
Hello,
My first print XYZ cubic.
I used Prusa Original Grey PLA. First layer 220 and then 215. Bed tempurature 60.
I believe I need to adjust Z axis still. I will check some youtube instructions.
Other observation was that X and Z axis cubic is 20mm, but Y axis 19mm. Any idea why this would happen?
Also wall layers are not the best all aread.
Thanks your advices
Best Answer by JKL:
Problem solved after one day troubleshooting. Y axis motor shaft was slipping little
so that cause not precise Y axis movement. Once I tightened hex skrew properly
print quality went immediately to expected level.
Strange was that any Prusa testing programs did not notice issue.
Posted : 24/04/2021 7:17 pm
RE: My first cubic print
Save your current  3MF project file, zip it up, and attach it to a reply here so we can see your part & settings and give better recommendations.
Posted : 24/04/2021 7:19 pm
Technical Ted
(@technical-ted)
A few questions:
1- Did you just get finished assembling a kit and this is one of your first prints?
2- Which printer are you using?
3- Did you go through all the setup instructions and first printing tests? Like the first layer calibration?
Ted
Posted : 24/04/2021 7:50 pm
JKL
 JKL
(@jkl)
Zip file added:
xyzCalibration_cube
-JKL
Posted : 24/04/2021 7:54 pm
JKL
 JKL
(@jkl)
Posted by: @technical-ted
A few questions:
Ted
Hello, Ted
This is mks3+ kit that I did assembly. First time 3D printing indeed.  I went through all setup steps including
1st layer calibration (that I am going to repeat now few times more to see if I can adjust more.
Posted : 24/04/2021 7:59 pm
JKL
 JKL
(@jkl)
Posted : 26/04/2021 1:20 pm
