MMU 2S Assembly
HoofedGibbon57
(@hoofedgibbon57)
MMU 2S Assembly
I just received a new MMU 2S, with a ton of parts in bags, and no assembly instructions. Anyone know where I can get a set of instructions from? Thank you.
Opublikowany : 14/06/2019 2:17 pm
gnat
 gnat
(@gnat)
RE: MMU 2S Assembly
They are in the Support section of the main Prusa website: https://manual.prusa3d.com/#_ga=2.83154646.1350976471.1560532599-1545635634.1548269646
There is also a MMU2 specific forum if you keep scrolling down on the main forum page: https://forum.prusa3d.com/forum/english-forum-original-prusa-i3-mmu2s-mmu2/
MMU tips and troubleshooting
Opublikowany : 14/06/2019 5:17 pm
gnat
 gnat
(@gnat)
RE: MMU 2S Assembly
Further, since you are posting in the MK3/MK3S section I am assuming that is your base printer.
My recommendation is to do the extruder modifications first, get the printer dialed back in, and then perform some test prints to confirm that the IR tower is positioned correctly and that the IR sensor is cooperating. In my case I couldn't get through a 20x20x20mm cube with the filament sensor turned on. If the IR sensor is not behaving correctly then getting the MMU to work will be a giant headache.
Once you can print with the IR sensor enabled and no false runout events, then proceed with assembling and installing the MMU.
Opublikowany : 14/06/2019 5:21 pm
Dave Avery
(@dave-avery)
RE: MMU 2S Assembly
manuals.prusa3d.com
pick your language and then
the printed manual is the printing handbook that should have been in the top of the box
Opublikowany : 14/06/2019 5:28 pm
