MK3s works briefly and then gears click and extrusion stops
[Solved] MK3s works briefly and then gears click and extrusion stops
nathanberger2001
(@nathanberger2001)
I built a mk3s from a kit a few weeks ago and I was able to do a 16 hour print in PLA with no issues. A few hours into my next print I noticed underextrusion and then eventually no extrusion. Since then I have not been able to complete a print. The printer will work briefly and then the extrusion will dwindle and then stop and the extruder gears will click. Once the extrusion has stopped I can start it again by clearing the nozzle with a needle. This initially lead me to believe it was a clog so I switched nozzles but the issue didn’t go away. I don’t believe it is a heat break issue as it happens so quickly after starting a print. I know it’s not an unmeltable item in the nozzle because it happens with a brand new nozzle. The only thing I can think of is that the nozzle is somehow cooling during the print until the filament in the tip hardens and clogs the nozzle until I clear the nozzle with a needle. I don’t know if this is actually and issue that can occur or what to do about it. I’ve included a photo of a failed first layer of a print.
Thanks in advance
Best Answer by cwbullet:
I think you are getting partial clogs of the hot end.  Have you tried a cold pull or used cleaner filament?
This topic was modified před 6 years by nathanberger2001
Napsal : 08/06/2020 4:13 am
Big Boy John
(@big-boy-john)
RE: MK3s works briefly and then gears click and extrusion stops
Posted by: @nathanberger2001
Thanks in advance
did you find out the solution allready becoz i have also the same i can print Some PLA rolls without probs but then even a few new filament rolls print a small time very good but then it starts clinking and the extrution stops:(
strange if i print ABS Tho no probs at all with PETG also no problem, really need some help with this:(
Napsal : 10/06/2020 9:02 am
Napsal : 10/06/2020 9:27 am
Big Boy John
(@big-boy-john)
@charles-h13
yeah tried that too:(
tried new nozzle too allways the same some work some dont using allways same brands never had this before:(
maybe need a new heatbreak??
This post was modified před 6 years by Big Boy John
Napsal : 10/06/2020 9:29 am
nathanberger2001
(@nathanberger2001)
It seems that the issue was a partial clog. I’m not sure how that’s possible because it still didn’t work when I switched nozzles but after doing many cold pulls it started working again. It there is some issue besides a clog that can be fixed by cold pulls it would be great if someone could let me know, but as of right now I don’t see how it could have been anything but a clog. It took about five cold pulls to fix it, so if anyone is having a similar issue I would recommend trying many cold pulls before giving up.
Napsal : 10/06/2020 6:55 pm
