MK3S - where can I find a ptfe "collar"?
redherring9
(@redherring9)
OK, I am still very new at this. In fact I am posting this in "assembly and first prints" because I have not yet been successful with a print (beyond the single layer Z calibration sheet - and a couple of XYZ calibration cubes)
However, boosted by these successes I tried to print something I thought would be useful and easy - a case. Things didn't go well... and I realised that the filament just wasn't moving. I tried a cold pull, and ended up snapping the filament just microns above the ptfe tube. I tried a 1.25mm rod but no luck even when at 250+ degrees.
Knowing I had a spare, I thought no worries, I can dismantle the extruder and replace the tube. This went reasonably easily.
UNTIL, I tried to take the old PTFE tube out of the hotend. At this point the BLACK LOCKING COLLAR broke (five pieces - ooops)
Where on earth can I get a new one? are they even called "locking collars" ?? thanks
Veröffentlicht : 08/04/2019 1:41 am
Re: MK3S - where can I find a ptfe "collar"?
Hi, where are you located?
if the USA, try
https://www.printedsolid.com/collections/e3d/products/e3d-bowden-collet
if the UK,
https://e3d-online.com/embedded-bowden-coupling-for-metal
if elsewhere pick your nearest reseller,
https://e3d-online.com/resellers
if you have plenty of time on your hands try,
https://www.aliexpress.com/item/Embedded-Bowden-Coupling-for-Metal-for-E3D-heatsink-bowden-tube-collet-for-E3D-hotend-HeatSink-heater/32891208745.html?spm=2114.search0104.3.9.5593d8a768DD8m&ws_ab_test=searchweb0_0,searchweb201602_3_10065_10130_10068_10547_319_317_10548_10696_10192_10190_453_10084_454_10083_10618_10307_10820_10301_10821_10303_537_536_10059_10884_10887_321_322_10103,searchweb201603_6,ppcSwitch_0&algo_expid=4d9531a2-d5d3-4369-be81-c4bac08acb9a-1&algo_pvid=4d9531a2-d5d3-4369-be81-c4bac08acb9a
Veröffentlicht : 08/04/2019 2:18 am
vintagepc
(@vintagepc)
Mitglied
Or, you can print one!
https://www.thingiverse.com/thing:1276626
Veröffentlicht : 08/04/2019 3:28 am
redherring9
(@redherring9)
Thanks Joan
I hadn't realised the collar was called a COLLET.
And as a Brit based in the US now, I appreciate the suggestions 🙂
ordered and will be here in time for the weekend
Veröffentlicht : 08/04/2019 5:37 pm
DubDee
(@dubdee)
RE: MK3S - where can I find a ptfe "collar"?
For USA I found one here:
https://www.filastruder.com/products/bowden-couplings-all-types?_pos=2&_sid=9e947e082&_ss=r&variant=32354109764
thanks to https://forum.prusa3d.com/forum/profile/17775/
haven’t fixed mine yet but this should do the trick
Veröffentlicht : 16/06/2021 2:28 pm
