MK3S Upgrade - Extruder Heater cable removal
OctoPope
(@octopope)
I'm working on upgrading my MK3 to MK3S. I haven't gotten far. On Step 3 "Unplugging the Extruder Cables" I'm stuck on the Extruder Heater connector. How does this disconnect? I'm guessing there's a catch below the overhang of this monstrous connector but I can't reach it, and really don't know if one actually exists.
Does anyone have any helpful hints as to how to disconnect this cable?
Respondido : 14/04/2019 1:00 am
OctoPope
(@octopope)
Re: MK3S Upgrade - Extruder Heater cable removal
Ok.... after digging around for a very long time with an allen wrench I eventually found the catch.
This should be called out as a HUGE pain point, perhaps with some helpful tips as how to get this done as I'm sure my way was NOT the proper way to do it.
Respondido : 14/04/2019 1:07 am
vintagepc
(@vintagepc)
Miembro
I'm pretty sure there is no catch on that connector (unless you have a different hardware revision than I do); I've had it out a few times without issue. It's just a tight fit because it's a high current connector...
Respondido : 14/04/2019 2:02 pm
