Mk3s stops multiple times requesting filament change. Filament sensor is OFF.
TMH
 TMH
(@tmh)
Been happily printing for a few weeks now after upgrading my printer to Mk3S. Mostly PETG, some ABS and Nylon, a little PLA.
Printing a job today with no name PC that I’ve printed successfully with in the past.  Profile is stock PolymakerPC max, Slic3r 1.42 beta 2 win 64.
The print is coming along just fine but it has stopped 3 times now and demanded a filament change. The filament sensor is OFF.  What gives?
Opublikowany : 02/05/2019 7:10 pm
RE: Mk3s stops multiple times requesting filament change. Filament sensor is OFF.
What version firmware?  If I recall, there were some sensor issues in 3.5.
Also, any chance you loaded MK3 firmware instead of MK3S?  A few have done that and had strange issues.
And one last thought: any chance you've played with Slic3r settings that deal with an MMU and/or mutiple filament colors?
Opublikowany : 03/05/2019 6:33 am
Andreas
(@andreas-11)
I also noticed this issue when using the Slic3r beta. It seems that it is very easy to unintentionally add colorchanges by clicking inside the slider bar in the layer view.
Opublikowany : 03/05/2019 8:52 am
