MK3S recalibrated himself during print, after losing his home point. Is that normal?
JF
 JF
(@jf-3)
Hello everyone,
today I recognised a strange behaviour of my MK3S and I’m not sure where it comes from. Maybe I could need some help.
Recently I moved in a small student apartment so I started building  a smart enclosure before I burn the hole place down.
While waiting for parts, I decided to renew my printer. First I updated my Prusa Slicer followed by the printer firmware, I cleaned  and greased all bearings, I changed nozzle and PTFE tube, I reassembled the printer and successfully passed the assembly check. Then I checked the belt tension, adjusted E-steps, layer height and extrusion multiplier and finally printed the first XYZ-Calibration Cube.
During the print my MK3S stopped 4 or 5 times and after he went to the home point, he continued printing.
For me it looks like he lost his home point and had to recalibrate.
Because I never saw this behaviour before, I’m not sure where it’s coming from and if it’s good or bad.
So before I run straight into a bigger problem, I wanted to know if someone made the same experience before?
Yours faithfully  JF
Opublikowany : 24/02/2021 4:31 pm
RE: MK3S recalibrated himself during print, after losing his home point. Is that normal?
What do the Fail Stats say?
I suspect minor crashes, if so check your axes for full, smooth, travel.
Opublikowany : 24/02/2021 4:44 pm
JF
 JF
(@jf-3)
@diem
Hi you were right, I reprinted the Cube and stand the hole time next to the printer.
This time the printer only  stopped once and I was able to read the massage:  crash detected.
Im not sure why the print crashed, for me it seems like the printer did nothing wrong and just stopped randomly.
Is there a way to get something like a crashlog from the printer?
This post was modified 5 years temu by JF
Opublikowany : 24/02/2021 7:10 pm
@jf-3
this could be a number of causes, If you didn't lubricate the linear bearings during assembly I would start by lubricating the smooth rods.
https://help.prusa3d.com/en/guide/lubrication-tips_23200
Opublikowany : 24/02/2021 8:21 pm
@jf-3
You have a crash summary on the printer.  It should indicate which axis is playing up.
Opublikowany : 25/02/2021 10:40 am
