MK3S+ problem
qodinij
(@qodinij)
MK3S+ problem
I finished the build and ran through the preflight check. I never had to change a settings during this until it got to printing the zig zag and fine tuning the Z. At this point I noticed that although pushing on the knob worked fine to choose selections, turning the knob had no effect. Everything else seemed to check out on the preflight, I just cant change any selections, dial in the Z and therefore print yet.
Thanks in advance.
192.168.l.lrouterlogin192.168.0.1
Respondido : 21/10/2021 9:58 pm
Dan Rogers
(@dan-rogers)
Um, your words are confusing
So you CAN select with the knob but you CAN'T select with the knob?  Which is it.  Either way, go to the e-shop, log in with the account you ordered your printer with, and wait 5 seconds.  When the chat bot shows up on your screen use it - if your knob doesn't work (or does it - get your story straight) - you need to chat with support.
Respondido : 22/10/2021 8:53 am
