MK3s New build. X axis failed
Mike
 Mike
(@mike-14)
I checked the pulleys, the are installed like they are supposed to be. The belt isn't rubbing on the orange parts.
I checked the System -> X number. It as 148. That's supposed to mean the belt is too tight. It wasn't but I loosened it a little anyway. No change
I lubed the shafts, even though they don't need it. The X axis starts at the left side, runs out to the middle, stops, goes back left, returns a little then fails. Help seems to be non-existent though I'm sure it isn't. I just can't find anything but this forum
Postato : 10/10/2020 11:17 pm
Mike
 Mike
(@mike-14)
RE: MK3s New build. X axis failed
I solved my problem. The idler pulley was too tight by 1/64 of a turn or less. Now to figure out how to use the printer beyond the files that came with it
Postato : 11/10/2020 2:25 am
The tension numbers are meaningless for belts. They show the current required to drive the axis, and a 150 means your bearings are way too tight. Did you grease them before installation?
A second issue is if the extruder back is torqued down too tight, it also crimps the bearings and causes excess drag. Loosening those screws near the bearings usually helps.
Postato : 11/10/2020 2:52 am
1 persone hanno apprezzato
Mike
 Mike
(@mike-14)
Posted by: @tim-m30
If this comment makes it through it'll be a partial duplicate.
Currently in moderation for some reason: "I solved my problem. The idler pulley was too tight by 1/64 of a turn or less. Now to figure out how to use the printer beyond the files that came with it."
I also loosened the extruder back, made sure the bearing was centered, and tightened it. I don't think I was quite as energetic as I was the first time I tightened it The printer is currently 1/2 way through printing it's second print. I'll print some real projects in the morning.
Postato : 11/10/2020 3:59 am
