MK3S MMU2S calibration procedure of the IR-sensor failure
Hi team, i just completed assembly of Mk3 to MK3S MMU2S upgrade. I spent hour trying to calibrate the IR sensor with no success. If i move it all to the left the value is 0, if all to the right is 1, so i assume the sensor is alive. I trued to slightly move to the right, but i never get the value to 1 neither with the allen key nor with the filament. Moving che chimney the value changes , so the sensor should be ok.
Napsal : 28/04/2019 7:18 pm
Topic starter
answered:
RE: MK3S MMU2S calibration procedure of the IR-sensor failure
I have solved following suggestions found in another discussion : https://forum.prusa3d.com/forum/original-prusa-i3-mmu2s-mmu2-assembly-and-first-prints-troubleshooting/ir-sensor-only-reads-0/#post-137513
Napsal : 29/04/2019 6:20 pm
