MK3S Kit > Selftest after assembly > Error X (and Y) axes wheel not tight
viehhausen5
(@viehhausen5)
Hallo
I finishes assembly of my MK3S and start self tests. Fanks ok, X axes "Riemenscheibe lose" means motor wheel not tighented
but it is . Belt tension seems ok too.
At first selft test I came to Y axes and got same error. I checked all screws and tensions. Now I am stuck at X axes first test.
I am a bit lost . Anything seems tight but whne reaching left or right end it is a hard stop with a NAG noise.
I am happy for any ideas as I am out of ideas
thank you for support Benno (bavaria)
Posted : 28/05/2020 9:03 am
RH_Dreambox
(@rh_dreambox)
RE: MK3S Kit > Selftest after assembly > Error X (and Y) axes wheel not tight
If you hear a humming noise when the X or Y axis reaches its end positions, you probably need to tighten the belts a little. The buzzing sound arises as the belt skips the cogs on the drive wheels. If you print something with loose belts, you will have big problems with layer shifts.
The only time you should hear a humming noise is when the Z axis calibrates its topp position.
Posted : 30/05/2020 11:56 am
viehhausen5
(@viehhausen5)
@rhdreambox
Hi
thank you this is the solution. i started wiht little tension not to overload the bearing in motor
now it runs absolutely perfect
Posted : 30/05/2020 12:30 pm
