MK3S keeps prompting unload filament
Visayan7
(@visayan7)
Hi everyone I'm currently having a massive issue in regards that the printer keeps telling me to unload filament. I had this printer for around a week or 2 and it prints amazingly if it does not stop to unload. It is starting to frustrate me as I bought this printer for reliability, not to wake me up in the night to unload and reload the filament.
It keeps telling me to unload filament usually after halfway through the print and 80% of the time 1 minute before it finishes printing.
Before you ask
The ir sensor is turned off
The cable is connected correctly
I printed different sized spacers which have made no changes
Even the prusa live support is confused about this which is why I'm asking here to get other opinions. There are other issues as well which again support is confused as what I told them should mean the printer is fine, which suggests that I might have a faulty printer somehow.
But I would like your opinions on what you think I should do.
Currently waiting for support to get back in a few days as the person helping me is trying to find out why this could be happening.
This topic was modified 4 years ago by Visayan7
Posted : 06/12/2020 12:13 pm
RE: MK3S keeps prompting unload filament
have you tried unplugging the filament sensor?
this will guarantee that you don't get erroneous signals from the sensor, then if the problem persists it is not in the sensor...
Posted : 06/12/2020 2:36 pm
Visayan7
(@visayan7)
@joantabb
I have not tried that. So I can disconnect the IR sensor and the printer will still continue to print?
Posted : 06/12/2020 3:45 pm
Visayan7
(@visayan7)
@joantabb
Ok problems still arise even without the sensor connected which suggests to me that it must be a hardware issue. The other problem I have is that I get incorrect belt tension results. The printer says the belt is too tight despite the belt teeth losing grip on the pulley making it quite loose, which could further support that it is hardware problems. What are you're thoughts?
Posted : 06/12/2020 7:35 pm
Rolf
 Rolf
(@rolf-2)
Hallo
Ich habe exakt das gleiche Problem. Ich habe meinen Drucker montiert, kalibriert, er hat auch den Probedruck (im Kalibrations-Modus) anstandslos gedruckt. Als ich den ersten Druck tätigen wollte forderte er mich auf das Filament zu entladen nach der Entladung habe ich neues Filament geladen dann fährt er den Druckstartpunkt an, um dann wieder in die Fillament entladen Stellung zu gehen usw....  Ich habe den Eindruck das es sich hier um ein Software Problem handelt....
Posted : 06/12/2020 10:06 pm
@visayan7
Did you lubricate the linear bearings during assembly,
If not now might be a good time to do some maintenance.
https://help.prusa3d.com/en/guide/printer-maintenance-tips_23200
let's see if we can get the printer moving properly first.
Posted : 06/12/2020 11:00 pm
Visayan7
(@visayan7)
@rolf-2
Your problem I believe is a little different caused by the sensor which is a common issue. I would suggest turning the sensor off on the LCD to see if it still prints. You either connected the cable incorrectly (depending on the printer you have) or might need a spacer under the sensor which helps. My case is that I can print but it's after halfway where suddenly it tells me to unload as well as 1 minute before it finishes.
Posted : 06/12/2020 11:01 pm
Visayan7
(@visayan7)
@joantabb
Bearings have been lubricated but with WD40 white lithium grease during assembly as well as on the bar.
Posted : 06/12/2020 11:03 pm
you could try loading the most recent firmware,
Do the X and Y axis move smoothly, by hand?
check that the X and Y idler wheels have a little side to side play and rotate freely,
If motion is still stiff,  try slackening the X axis Bank Plate, about half a turn on the screws to loosen their grip on the linear bearings
If Y axis is still stiff, check for a gap between the toothed motor pulley and the motor mount and motor body
if problems still persist, try looosening the u bolts a  little
Posted : 07/12/2020 12:12 am
Visayan7
(@visayan7)
@joantabb
It had the most recent firmware and I tried an older firmware with the same results. The axis appears to move smoothly when moved by hand, I have another printer so can compare that it moves just as well as the other printer yet the Prusa layer shifts a lot more than the other printer, more when the speed is lowered.
Posted : 07/12/2020 12:16 am
Visayan7
(@visayan7)
@joantabb
Like I said nothing appears to be stiff. The X and Y are able to move smoothly. Maybe the bearings need more lubricant on the inside? But sorting the layer shifting is pointless until I can sort out why it keeps unloading filament even with the sensor removed,
Posted : 07/12/2020 12:40 am
Rolf
 Rolf
(@rolf-2)
Hallo
Ich war dann ein wenig blind .....!! Denn ich hatte den Filamentsensor an den falschen Slot angeschlossen seit dem ich das geändert habe ist alles gut.
Posted : 07/12/2020 7:16 pm
Visayan7
(@visayan7)
@rolf-2
Glad you sorted out. Still having issues with mine.
Posted : 09/12/2020 4:33 pm
