Mk3S and adding MMU2.5S Assembly Instructions
MikeJ
(@mikej)
I purchased both the Mk3S and the MMU2.5S in September of 2020. I haven't installed the MMU2.5S yet and I am confused as to the assembly instructions saying that the kit is no longer sold. Can someone point me to the correct assembly instructions or do I need to upgrade to Mk3S plus  before I can do anything? There doesn't seem to be clear instructions anywhere.
Thanks for any help.
Mike J.
Veröffentlicht : 14/02/2022 3:41 pm
Robin
(@robin)
RE: Mk3S and adding MMU2.5S Assembly Instructions
As far as I know, there is no MMU2.5S. Are you sure about that description?
Veröffentlicht : 14/02/2022 3:46 pm
MikeJ
(@mikej)
Good catch, here is what I ordered and have been using without the MMU.
 PRI-MK3S-KIT-ORG-TXT-PEI Original Prusa i3 MK3S kit
Here is my MMU
MMU2S-MK3S-ORG  Original Prusa i3 MK2.5S/MK3S Multi Material 2S upgrade kit (MMU2S)
I couldn't find an assembly instruction from the MK3S (non-plus) to the MMU2S
Thanks for your speedy answer.
Mike J.
Veröffentlicht : 14/02/2022 3:55 pm
Robin
(@robin)
You can upgrade your MK3S with the MMU2 kit. If you bought it September 2020 you probably have an MK3S and an MMU2 kit.
You can use that to upgrade without the need of an upgrade to MK3S+ using this assembly instructions:
https://help.prusa3d.com/en/guide/1-introduction_36832
Veröffentlicht : 14/02/2022 4:01 pm
MikeJ
(@mikej)
Thank you Sir!!
Greatly appreciated.
Veröffentlicht : 14/02/2022 4:03 pm
