MK3 to MK3S+... sort of...
ashley.h3
(@ashley-h3)
I own multiple Prusa MK3 printers, over time the filament sensors have slowly begin to fail as expected. At one point there was a MK3 to MK3S kit available to upgrade to the more reliable IR based filament sensors but that does not appear to be available anymore since prusa has upgraded beyond the MK3S now. My question is, if I download and print the MK3S+ extruder parts is there anything else I will be missing or will need other than a ball bearing and a couple of magnets to update to the MK3S IR based Filament sensors? obviously I will be pulling the MK3 extruders apart and re using everything I can, I just don't want to be mid way through the upgrade and be missing a screw or have the wrong size ball bearing/magnets.
Opublikowany : 09/01/2023 7:30 pm
Hello
(@hello)
RE: MK3 to MK3S+... sort of...
Here is the upgrade kit it goes from mk3 or mk3s to mk3s+
https://www.prusa3d.com/product/original-prusa-i3-mk3-s-to-mk3s-upgrade-kit/
Opublikowany : 09/01/2023 7:56 pm
