MK3 Stops during print
ingo.b
(@ingo-b)
Hello together,
I have the problem that my Prusa i3 mk3 stops during prints (bought 2018-07).
It doesn't matter if I print from SD card or over USB connection.
Here are the last informations from printer:
17:24:12.531: N40482 G1 F2100 E1655.31675
17:24:12.531: N40483 G1 F720 Z1.18
17:24:12.535: N40484 G0 F7071.4 X125.251 Y161.677 Z1.18
17:24:12.538: N40485 M204 S1900
17:24:12.624: N40486 M205 X20 Y20
17:24:12.657: fsensor_stop_and_save_print
17:24:12.661: fsensor_oq_meassure_start
17:24:12.665: echo:Enqueing to the front: "G1 E-3 F200"
17:24:12.669: echo: too long extrusion prevented
17:24:12.673: echo:Enqueing to the front: "G1 E3 F200"
17:24:14.476: fsensor_oq_meassure_stop, 9 samples
17:24:14.480: st_sum=1611 yd_sum=73 er_sum=0 er_max=0
17:24:14.484: yd_min=6 yd_max=10 yd_avg=8 sh_avg=2
17:24:14.485: fsensor_err_cnt = 0
17:24:14.488: fsensor_restore_print_and_continue
17:24:17.490: Resend: 40461
17:24:17.502: Resend: N40461 G1 F2100 E1656.03589
17:24:17.502: Resend: N40462 G1 F3300 X161.977 Y128.007 E1656.06476
17:24:17.502: Resend: N40463 G1 X162.599 Y127.638 E1656.10611
17:27:29.334: echo:busy: processing (93)
Does anyone has an idea?
Respondido : 06/02/2019 5:41 pm
Re: MK3 Stops during print
Turn off the filament sensor. It's been nothing but headaches for me, and many others, even stopping with nice and opaque color dense filaments during the middle of a spool. Others have gone to the trouble of adding a roller bearing to help the intermittent nature of the thing, many people just stopped using it.
Respondido : 07/02/2019 6:02 pm
ingo.b
(@ingo-b)
Hmm.
But it worked some month and at the moment I am working at a stormtrooper costume.
So I print only white colored PLA with 0.6mm nozzle. This means without sensor I have to wake up every night to change the filament. 🙁
But you are sure it is the filament sensor?
Because inside last command line it says:
Respondido : 07/02/2019 7:21 pm
No - I am not sure it is the filament sensor. But I am sure the only times I have had my printer stall, stutter, or fail mid print with no indication (printer just sitting idle - mid print) is when I have had the filament sensor enabled.
Respondido : 09/02/2019 8:40 pm
