MK3 kit print issue
Byulos
(@byulos)
MK3 kit print issue
I have been having issues printing a 9 tailed fox model with my MK3 kit I got running a few weeks ago. The fox portion seems OK, but the tails have these ridges on them, and they are consistent across all the tails at the same height. The model was facing forward during printing.
I thought maybe it was the y axis belt, but I tightened it up last night and checked the gear on the motor and the pully up front. I then ran another one and it looks the same. Any ideas?
Respondido : 13/08/2018 10:20 pm
Bytor
(@bytor)
Re: MK3 kit print issue
I had a similar problem before... it was related to the perimeters and infill. I increased the perimeters and it went away. Not sure if its the same issue with yours, but worth to take a look. If you can bring the object back up in Slic3r and check out the layers and look at how the infill interfaces with the perimeters.
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Respondido : 14/08/2018 1:37 am
