Missing parts for MK3S build at #7, Heatbed and PSU assembly.
Order 192380380
Up to the heatbed/PSU assembly, all went well. Now at the heatbed portion, I have no small bag of screws, nuts, spacers, and whatever else should be in there. The bag for 7 only contained the four cables, and the cable cover and clip.
I need someone to send the small bag of parts so I can get on with this build.
I could not find a simple way to contact Prusa other than via this forum.
Thanks in Advance.
Opublikowany : 17/12/2019 11:16 pm
RE: Missing parts for MK3S build at #7, Heatbed and PSU assembly.
Click the EShop button above, sign in, then click the Chat button in lower right.
That is Support - and they will fix you up.
This post was modified 6 years temu by rmm200
Opublikowany : 18/12/2019 1:47 am
Excellent illustration of why it is wise to check all items are present before you begin work.
Hope you get your parts soon!
Opublikowany : 18/12/2019 6:57 am
