M3x12b screw stripped
kenneth.g4
(@kenneth-g4)
Hi, I was trying to tighten the M3x12b screws onto the heatbed, but ended up stripping some of the screws. Where can I order replacements? I went to https://shop.prusa3d.com/en/ but could not find replacement screws.
Publié : 26/06/2018 7:49 am
stahlfabrik
(@stahlfabrik)
Re: M3x12b screw stripped
There are screws in the spare bag! And yes, the quality of theses screws is not good. I needed three from the spare bag because of their varying head diameter, so they sit flush in the heatbed
Publié : 26/06/2018 4:16 pm
stahlfabrik
(@stahlfabrik)
And if you need more: support chat should be able to help
Publié : 26/06/2018 4:17 pm
Gato
 Gato
(@gato)
Any recommendations for removing one of these heatbed screws that "lost their head"? 🙂
Publié : 26/06/2018 6:27 pm
kenneth.g4
(@kenneth-g4)
Ah, the spare bag! I don't recall those screws being inside, but will check again. Thanks!!
Publié : 27/06/2018 8:20 am
stahlfabrik
(@stahlfabrik)
Maybe use a hex screw driver of one size bigger.
Or epoxy a screw driver on.
Publié : 28/06/2018 7:31 pm
Fotoman
(@fotoman)
I found a small flat blade screwdriver worked.
Proud owner of a Mk3 that is producing very nice prints. There is room for improvement as I learn more about it, but so far I am very happy.
Publié : 29/06/2018 1:33 am
Gato
 Gato
(@gato)
Thanks guys
Publié : 29/06/2018 3:45 am
jarl-dk
(@jarl-dk)
RE: M3x12b screw stripped
I know the thread is old.
@gaston-d3: What method did you end up using taking out the screw?
Thanks.
Publié : 22/04/2020 9:51 am
