Lost an E-axis bearing - showstopper?
I got to the point in the assembly where you're supposed to stick the little axle into the extruder idler, through pulley with its bearings (chapter 5, step 4, part 3). It got a little stuck and while jiggling I dropped the pulley. The bearings popped out and one of them went to the shadow realm. Is proceeding with just one bearing a bad idea? If I need to replace it, any recommendations as to where I should go? Thanks in advance!
Publié : 19/04/2018 12:41 am
