Loose X and Y axis belts. How to tighten them?
luca.r
(@luca-r)
By just visually observing the belts during printing, they seemed loose to me.
I checked via LCD Menu - Support - Belt Status and the values reported are
X: 291
Y: 285
The 3D printing handbook says in 13.4 that values 240 +/- 40 are good, so I am in fact outside this range for both belts.
Which is the correct way of tightening them?
Thanks,
Luca
Napsal : 20/05/2018 6:00 pm
Gato
 Gato
(@gato)
Re: Loose X and Y axis belts. How to tighten them?
X belt could be slightly tuned by following https://manual.prusa3d.com/Guide/4.+Z-axis+assembly/509?lang=en step 18. However, I do not think it will give you enough margin to be in range.
To adjust Y belt this is what I did:
1. Turned off printer (I unplugged it too)
2. Release tension on Y belt ( https://manual.prusa3d.com/Guide/2.+Y-axis+assembly/507?lang=en step 36)
3. Clean the table from any dust
4. Turn the printer to its side (PSU facing down). This will give you access
5. Make Y belt tighter ( https://manual.prusa3d.com/Guide/2.+Y-axis+assembly/507?lang=en step 34)
6. Remember to tighten plastic of step 2
To adjust X belt (my guess is since I never did it)
1. Cut zip ties of https://manual.prusa3d.com/Guide/5.+E-axis+assembly/510?lang=en steps 39 and 40
2. Unplug cable to filament sensor (step 28)
3. Remove 5 screws of X-carriage-back (step 37)
4. Adjust belt according to https://manual.prusa3d.com/Guide/4.+Z-axis+assembly/509?lang=en step 13
5. Put everything back
Napsal : 20/05/2018 8:29 pm
1 lidem se líbí
thrawn86
(@thrawn86)
I had a lot of trouble with Y, since the belt holder just wouldn't grip the teeth without slipping at anything close to proper tension. A good pair of lockjaw pliers will be your friend to get it tight by hand, otherwise something like mattyvee's tensioner works really well.
https://www.thingiverse.com/thing:2786671
I found it much easier to install and tension the x belt with the whole axis off of the frame, but thats definitely not ideal.
but now i'm sitting at 238/219 so all is well.
Napsal : 21/05/2018 12:08 am
Olef
 Olef
(@olef)
I second this adjuster. It works well!
Napsal : 21/05/2018 7:24 am
sworcester
(@sworcester)
At what point does it again check tension?
Seems that if I loosen it all up, or move the belt a couple notches, I still get the same numbers.
Is there a recalibration or self check for it to recalibrate those number?
Napsal : 24/05/2018 10:20 pm
Gato
 Gato
(@gato)
Belt tension numbers in lcd get updated after running self test.
Napsal : 25/05/2018 1:29 am
