live z height > 2.00
Michael Oakley
(@michael-oakley)
I adjusted my pinda using the zip tie, recalibrated, did bed leveling using octo print bed visualizer
SIlicone tube spacer mod
and my live z is 2.00 and still not good ?
Postato : 20/04/2024 1:50 pm
RE: live z height > 2.00
If you’re close to or above -2, I would reposition the PINDA higher.
May sound counter-intuitive to move the PINDA higher, but by doing so the nozzle can move closer to the print bed before the PINDA triggers. For an illustration of relationship of distance of PINDA to nozzle and sheet, see
The Super PINDA should have about 1.5 mm distance between nozzle and sensor, so that you’re around -1 when your Live Z is correct. That gives you enough wiggle room up and down.
Instructions for adjusting the PINDA are in:
Mini: https://help.prusa3d.com/en/guide/how-to-replace-superpinda-mini-mini_179912
Mk3S: https://help.prusa3d.com/en/guide/how-to-replace-superpinda-mk3s-mk3s_179920
I put this little gadget on Printables to help position the PINDA: https://www.printables.com/model/57192
Works better than zip ties or credit cards, which have less well-defined heights.
Postato : 20/04/2024 1:58 pm
Michael Oakley
(@michael-oakley)
when i see people with live z values of .6 i scratch my head
thanks
Postato : 20/04/2024 2:00 pm
Michael Oakley
(@michael-oakley)
well i moved it up and it is still 1.95 when i go through your steps
Postato : 21/04/2024 11:04 am
Eef
 Eef
(@eef)
Posted by: @michael-oakley
The height you now have is the height of the ziptie. So that is OK.
Please use an old creditcard instead. That is about 0,8 - 1 mm
When you do the Live Adjust and go dot with -0.600 to -0.800 you get the same numbers as others.
to sumup:
- You use the ziptie, creditcard or whatever to give the PINDA a known distance of the bed.
- with setting the Live adjust you narrom this down. (NB: If you would go down to the bed with the nozzle (DO NOT DO THAT IN REALITY) you will see the same number as the height of the ziptie/creditcard).
- The difference between thickness and live Z result is your actual nozzle/printing height.
Postato : 21/04/2024 11:43 am
