Line Number is not Last Line Number+1....
Kittehn
(@kittehn)
I have successfully completed my MK3S kit and passed all the self tests and calibrations (at least I believe I have). Everything looks okay and the machine says it is. I have attempted to print several things with no luck. At first, I tried a something from the SD card that came with it. Then I connected the printer to my computer via USB and loaded a model (the RPi frame) into the the prusa slice and went to print.
Each time I have attempted to print, the printer would ask to unload the filament and then reload the filament. Then it would act like it was going to print, then repeat the unload/load process. Whole using the Slicer software, it would receive an error "Error:Line Number is not Last Line Number+1, Last Line: 20 [ERROR] Error:Line Number is not Last Line Number+1, Last Line: 20".
I also attempted to use the software CURA and got the same results. I am not sure what I am doing wrong. I have also updated the firmware. I am not sure what else to do or if I a, doing something wrong. Any help is greatly appreciated. Thanks!
Posted : 04/07/2020 4:34 pm
Peter M
(@peter-m)
RE: Line Number is not Last Line Number+1....
Use the sd card, put gcode on to it, and then put the sd card in the printer and start the print.
Try this.
First disable the filament sensor in the settings in the printer, this works often bad, it depends on the filament you are using, then printer will not stop anymore to change the filament.
Posted : 04/07/2020 9:45 pm
