lcd screen problem
Hello this is my third print.
At start everythink was perfect even in the first print. Today when i open the printer the lcd screen start to act weird
i see everytying inside the menu 2 times. i can steel select and work it but it is realy anoying
please help
Opublikowany : 23/02/2019 8:30 pm
Re: lcd screen problem
might want to contact support, the displays have a high failure rate . they're cheap and susceptible to static shocks.
Opublikowany : 23/02/2019 11:16 pm
I've seen this and did a full reset with memory wipe; had to do Wizard calibration again, etc., but the problem went away.
Opublikowany : 23/02/2019 11:19 pm
