LCD and USB won't function
gordon.dougal
(@gordon-dougal)
Hi, I've just assembled a MK3S kit and I'm having trouble with start-up. When I power on the LCD just shows rectangles. Read a few posts but nothing has worked - thought I'd check if anyone has any ideas. Things I've tried
  • Rechecked each connection on board - including correct placement of LCD cables (if I switch them LCD is blank)
  • Checked all fuses
  • Disconnect all but LCD and power cables and try booting - same rectangles
  • Update firmware via USB - just times out (COM port is there - if I disconnect cable it immediately fails - if connected it takes a few seconds to fail) - error below:
avrdude-slic3r -v -p atmega2560 -c wiring -P COM5 -b 115200 -D -U ...Using Port : COM5
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude-slic3r: stk500v2_recv(): timeout
avrdude-slic3r: stk500v2_getsync(): timeout communicating with programmer
avrdude-slic3r: Could not open port: COM5
Is there anything else I can try, or is it a dead board? The green light at the top of the board (next to USB port) is solid green when power is on, so assuming it's not a power/PSU issue.
Thanks!
Publié : 22/02/2020 5:36 am
rmm200
(@rmm200)
RE: LCD and USB won't function
You have entered Customer Support area.
Click the EShop button above, login and/or register, and a Chat button will eventually appear.
Support can step you through it far better than we can through posts.
Note: Chat is also far more effective than EMail in getting support. They are very responsive.
Publié : 22/02/2020 3:55 pm
