Layer Shifts
asher.r
(@asher-r)
Layer Shifts
I just recieved and built the MK3 kit. I started printing and all of my prints so far (all just benchmark tests) have been layer shifted. I have tried adjusting the u-bolts. I'm not sure what i need to do to fix this. Does anyone know?
Opublikowany : 28/10/2018 4:05 pm
termlimit
(@termlimit)
Re: Layer Shifts
I would check your toothed idlers on the axis motors, that looks like belts slipping. How was first layer?
Opublikowany : 28/10/2018 4:53 pm
asher.r
(@asher-r)
Re: Layer Shifts
The first layer is pretty much always fine.
Opublikowany : 28/10/2018 4:59 pm
termlimit
(@termlimit)
Re: Layer Shifts
Are your belts tight enough? Also your idlers? Looks like you are slipping somewhere.
Opublikowany : 28/10/2018 5:07 pm
asher.r
(@asher-r)
Re: Layer Shifts
I just tightened the screws on the Y axis motor. They weren't that tight. It seems to have worked, but we'll see.
Opublikowany : 28/10/2018 5:09 pm
termlimit
(@termlimit)
Re: Layer Shifts
Nice, update if possible with results!
Opublikowany : 28/10/2018 5:37 pm
asher.r
(@asher-r)
Re: Layer Shifts
It worked! Thank you for your help. 🙂
Opublikowany : 28/10/2018 7:41 pm
termlimit
(@termlimit)
Re: Layer Shifts
Not a problem!
Opublikowany : 28/10/2018 7:50 pm
