Layer shifting in Y-Axis, more noticeable with PETG
Hobbyisteresis
(@hobbyisteresis)
Hello all. I'm fairly new to 3D printing and could use some guidance. I assembled a kit and made more than a dozen prints so far. I noticed that there were more significant layer shifting issues with PETG. I believe that I have Y-axis layer shifting issues and wanted to get some input from others.
  • I checked and all of the tensions are between 240 and 300. Y Axis tension is 244.
  • I cannot see anything blocking the path and when pushed manually, it seems to be smooth all around.
  • I recalibrated and it seemed to make layer shifting worse.
I printed the same 3D model using the following filaments:
  1. Printed using Hatchbox PLA Red (Printed the best IMO)
  2. Recalibrated 1st layer and used Overture PETG Black
  3. After full calibration, used Overture PETG White
I performed full calibration between black and white Overture PETG filaments and things seemed to get worse, LOL. I am stuck and don't know what I should be trying next. Any help would be appreciated! I am assuming that it's isolated to Y-Axis problem, because the layers are shifting to the left (layers sticking out in the last picture).
Best Answer by Hello:
check the small screw on the gear conecting to motor
Veröffentlicht : 01/01/2023 11:21 pm
Hello
(@hello)
RE: Layer shifting in Y-Axis, more noticeable with PETG
Veröffentlicht : 02/01/2023 3:24 am
Hello
(@hello)
and only do calabration on 1 color as diffrent colors can vary slightly take a picture of the axis motor and rods and the underneeth of the bed thanks
Veröffentlicht : 02/01/2023 3:26 am
Hobbyisteresis
(@hobbyisteresis)
Thank you for the reply @hello! You are right.
I actually tightened the set screws before seeing your reply and have been printing without noticeable layer shifts! I thought I had tightened all the screws when building the kit, but apparently not.
Since you are a SME… I have another issue that I’m scratching my head on. Do you think it has to do with the print/fan direction? There was only one noticeable issue on this run.
Veröffentlicht : 05/01/2023 12:45 am
Hello
(@hello)
please take a photo of your extruder from all angles so i can see if its built right thanks
Veröffentlicht : 05/01/2023 12:59 am
Hello
(@hello)
and what fillament did you use in that run
Veröffentlicht : 05/01/2023 1:02 am
Hobbyisteresis
(@hobbyisteresis)
It was printed using Overture PETG at default settings (“Generic PETG”). I kicked off another print, so I will post pics of the extruder tomorrow. Thanks again!
Veröffentlicht : 05/01/2023 1:30 am
Hello
(@hello)
ok all good
Veröffentlicht : 05/01/2023 1:41 am
Hobbyisteresis
(@hobbyisteresis)
Here are the pics. It’s printing fairly well right now though. Not too many issues as far as I can tell, but you might see something. Please let me know!
Veröffentlicht : 06/01/2023 1:21 am
Hello
(@hello)
I would tighten the extruder screw slightly
Veröffentlicht : 06/01/2023 3:55 am
