Layer shifting in Y-Axis, more noticeable with PETG
Hello all. I'm fairly new to 3D printing and could use some guidance. I assembled a kit and made more than a dozen prints so far. I noticed that there were more significant layer shifting issues with PETG. I believe that I have Y-axis layer shifting issues and wanted to get some input from others.
- I checked and all of the tensions are between 240 and 300. Y Axis tension is 244.
- I cannot see anything blocking the path and when pushed manually, it seems to be smooth all around.
- I recalibrated and it seemed to make layer shifting worse.
I printed the same 3D model using the following filaments:
- Printed using Hatchbox PLA Red (Printed the best IMO)
- Recalibrated 1st layer and used Overture PETG Black
- After full calibration, used Overture PETG White
I performed full calibration between black and white Overture PETG filaments and things seemed to get worse, LOL. I am stuck and don't know what I should be trying next. Any help would be appreciated! I am assuming that it's isolated to Y-Axis problem, because the layers are shifting to the left (layers sticking out in the last picture).
RE: Layer shifting in Y-Axis, more noticeable with PETG
check the small screw on the gear conecting to motor
and only do calabration on 1 color as diffrent colors can vary slightly take a picture of the axis motor and rods and the underneeth of the bed thanks
Thank you for the reply @hello! You are right.
I actually tightened the set screws before seeing your reply and have been printing without noticeable layer shifts! I thought I had tightened all the screws when building the kit, but apparently not.
Since you are a SME… I have another issue that I’m scratching my head on. Do you think it has to do with the print/fan direction? There was only one noticeable issue on this run.
please take a photo of your extruder from all angles so i can see if its built right thanks
and what fillament did you use in that run
It was printed using Overture PETG at default settings (“Generic PETG”). I kicked off another print, so I will post pics of the extruder tomorrow. Thanks again!
ok all good
I would tighten the extruder screw slightly
